daniel@procarpet
- Joined
- Sep 7, 2008
- Messages
- 3,797
Anybody use this hose? Is there a better hose than this one?
http://interlinksupply.com/index.html?i ... ++++++++++
It is a prefersnce thing again,paraflex is a third of the weight,goes to 230(good enough)1750 psi,if you need more you are in the wrong biz,goodyear will hold up to heat a little better,but you can also get BLACK DEATH,and it too gets wrapped around your vac hose.So it is back to "what do you like"not"what does Marty Mcfly like"admiralclean said:If that Parflex is that plastic crap somebody sold me a couple years ago, forget it. After tripping over the coils that wrap around you legs a dozen times, or so, I finally threw that crap in the dumpster and went back to Goodyear.
danielc said:One more thing about "the black death." I have had this happen to me a couple times if I do not have any jobs for a few days and I have a bad hose. I have always been able to rinse it out of the carpet. Once the black stuff starts comming out, I always disconnect the wand and go outside and key the wand until all of it has been flushed out of the hose and then finish the job. The black stuff rinses very easily from carpet. Why have some of you had to replace the carpet?
The Magician said:Hey Larry I had alot of problems with neptune. I like the Parker but find its too coily.
