Jeremy;
The difference in HP is due to the rating system.
A 5 HP electric motor is designed to run @ the 5 HP power level.
A gasoline 5 HP engine will deliver 5 HP for short-term usage. For continuous power, most manufacturers would rate it @ 75-80+% of that maximum HP.
This % has increased in the last few years as engineering has improved on the gasoline engines.
With our most popular TM engine, the water-cooled 31 HP Kohler, the maximum continuous output is 26 HP or 84% of the rated HP.
The #4MP blower on that model requires 16.7 HP at maximum rated output. The pump adds another 1-2 HP.
Total HP required is about 70% of that available continuously.
Engineering over SOA Standards
