Torque & HP Rating from gas & electric motors...
Jeremy
Jeremy
Can anyone explain the difference?
I know 5 hp electric is stronger than 5 hp gas which is stronger than the same 5 hp motor converted to propane...
What is the ratio/conversion/correlation?
5 hp is 5 hp
The torque is what is different
An electric motor runs at peak power continuous. The more load the more amps.
A gas motor can operate with variable power levels. IE 1000 rpm or 2000 rpm ect
If your looking at what hp does it take to spin a blower then you need to look at the engine rating at the rpm in which you intend to use it.
Jeremy;
The difference in HP is due to the rating system.
A 5 HP electric motor is designed to run @ the 5 HP power level.
A gasoline 5 HP engine will deliver 5 HP for short-term usage. For continuous power, most manufacturers would rate it @ 75-80+% of that maximum HP.
This % has increased in the last few years as engineering has improved on the gasoline engines.
With our most popular TM engine, the water-cooled 31 HP Kohler, the maximum continuous output is 26 HP or 84% of the rated HP.
The #4MP blower on that model requires 16.7 HP at maximum rated output. The pump adds another 1-2 HP.
Total HP required is about 70% of that available continuously.
Engineering over SOA Standards
MerCrewser
HP is RPM x Torque divided by 5252. Engines make a maximum torque at a certain RPM, thus Max HP at a certain RPM. Electric motors can make maximum torque at 0 RPM.
