Trailer coming soon
Tampa bay
Joe
Well I finally order it. Should be ready for pick up on about 3 weeks
It is going to be a:
6 x10, v nose, side door, ramp, tandem axle,
I will like to see some pictures of your trailer I want to have an idea of how I am going to secure everything inside the trailer
Show me some pictures please
Thanks
Kipp
Phoenix, AZ
kip
Here's a 6x12 with a 470 I had...
Kipp
Phoenix, AZ
kip
You have room on either side of TM
Or up front...
You can actually get a rotary, sprayers and other tools on side of TM
carpetcleaner
Gilbert, AZ
Rob Litwin
I don't keep any gallons on the top shelf. I have my wands with the bottoms by the reels and handle on the top shelf. I use a long strap to keep everything in its place.
Kipp
Phoenix, AZ
kip
6X10 tandem is a super hard trailer to find.
It will pull really good.
Get your nose weight right. Are you mounting fuel cell on nose?
Tampa bay
Joe
I know I have to special order mine is goin to be built just for me
I do not know wha you mean by get your nose waight right
Or
Mounting fuel cell on nose?
carpetcleaner
Gilbert, AZ
Rob Litwin
I was going to have one made with the entire side made into a door that would lift up and become an awning. There are concession trailer/trucks that have doors like it. I placed the ordered which was going to take 4-6 weeks and a few days later my TM/van caught fire, so I needed to find something in stock.
Tampa bay
Joe
they are going to star making it next week i can still make changes if i want to
one thing i should had ask before V Nose or flat Front?
i order it v nose but now that i see $1kaday trailer looks like it may be easier to put stuff in side
another term is "tongue weight"
the general rule of thumb is 10% of the gross weight needs to be on the tongue/ball/hitch
example, if trailer + load inside = 4000 pnds, the load should be distributed so that at least 400 pounds is on the ball/hitch
It doesn't have to be "perfectly" balanced ..but too light of tongue weight will cause the trailer to sway back and forth at hi-way speeds .
if trailer and load is 4000+ pounds and you can lift the tongue off the ground by hand, it's way too light and the load needs adjusted forward of the axle
Shane T
Waukesha, WI
Shane Tiegs
Some don't like to have the fuel source inside the trailer so they will mount an approved fuel cell outside, sometimes on the tongue. I personally don't see the problem with it being inside as long as it is don't safely. Either way be sure the fuel lines are routed out of way and protected from any chaffing or puncture possibilities. It is also good to place it in the coolest spot possible.
