Triple Strength Zip Dri Encap TS from CleanMaster Raffle
HydraMaster ZipDri Encap TS GiveAway!
ZipDri Encap TS
Triple Strength Low Moisture Encapsulation Carpet Cleaning Solution
ZipDri Encap TS allows the carpet cleaning professional to take advantage of the many strengths of a low moisture soil encapsulation system such as eliminating wicking and reoccurring spills; tripled cleaning productivity rates; extending the carpet life-cycle, greatly reduced area downtime; and positive appearance management. ZipDri Encap TS keeps carpet looking its very best with less effort and increased productivity. ZipDri Encap TS is the most ultra-concentrated encapsulation cleaner on the market, utilizing only 2 to 4 ounces of solution per gallon of water. ZipDri Encap TS is the only encapsulation cleaner that contains Tritanol™ - an integrated blend of specialized encapsulating polymers, organic sequestrants, and specialty surfactants. Tritanol helps separate ground in soiling from the carpet fiber, encapsulates soil and holds it in suspension, and makes it easier for subsequent vacuuming to extract more soil than conventional encapsulation cleaners. ZipDri Encap TS does so much more than dry down to a brittle, non-resoiling residue. It cleans better. Lasts longer, and helps carpet stay cleaner longer. ZipDri Encap TS can be effectively used with virtually any low moisture agitation system – CRCB (Counter-rotating cylindrical brush); triple planetary rotary brush; oscillating or orbital brush or pad; and with absorbent bonnet pads. When carpets are cleaned according to directions with ZipDri Encap TS, you will experience drying times between 10 minutes and an hour. There is no faster, easier way to make carpet look better and stay cleaner longer. ZipDri Encap TS will work wonders on commercial glue down carpets, but can be safely and effectively used on synthetic and wool commercial and residential carpet. Best of all, ZipDri Encap TS leaves the room smelling clean and refreshed, and qualifies as a SafeClean formula. With ZipDri Encap TS and the right solution applicator and agitation machine, you can experience cleaning rates of up to 5000 square feet per hour.
  • ZipDri Encap TS allows the carpet cleaning professional to take advantage of the many strengths of a low moisture soil encapsulation system such as eliminating wicking and reoccurring spills; tripled cleaning productivity rates; extending the carpet life-cycle, greatly reduced area downtime; and positive appearance management.
  • ZipDri Encap TS is the most ultra-concentrated encapsulation cleaner on the market, utilizing only 2 to 4 ounces of solution per gallon of water.
  • ZipDri Encap TS is the only encapsulation cleaner that contains Tritanol™ - an integrated blend of specialized encapsulating polymers, organic sequestrants, and specialty surfactants. Tritanol helps separate ground in soiling from the carpet fiber, encapsulates soil and holds it in suspension, and makes it easier for subsequent vacuuming to extract more soil than conventional encapsulation cleaners.
  • ZipDri Encap TS can be effectively used with virtually any low moisture agitation system – CRCB (Counter-rotating cylindrical brush); triple planetary rotary brush; oscillating or orbital brush or pad; and with absorbent bonnet pads.
  • ZipDri Encap TS will work wonders on commercial glue down carpets, but can be safely and effectively used on synthetic and wool commercial and residential carpet. Best of all, ZipDri Encap TS leaves the room smelling clean and refreshed, and qualifies as a SafeClean formula
  • Available Sizes: gallon
Directions:
As a low moisture encapsulation cleaner
  1. Always pre-test all cleaning solutions in an inconspicuous area for colorfastness prior to application.
  2. For normal soiling, mix one part Zip-Dri Encap TS with 32-64 parts hot water (2-4 ounces of solution with a gallon of water) into a pump-up, electric, or battery powered pressure sprayer. For heavily soiling, mix one part solution with 16 parts water.
  3. Apply the ready-to-use solution as a mist in a consistent, overlapping pattern. Use more solution in heavily soiled areas. For best results, apply with electric or battery powered sprayer.
  4. Agitate the solution into the carpet with a counter rotating cylindrical brush machine, triple planetary rotary brush machine, oscillating or orbital agitation machine, or rotary shampoo brush.
  5. If using ZipDri Encap TS with a bonnet pad system, mix solution 8 ounces to a gallon, and apply to carpet and both sides of bonnet pad. Proceed to clean in normal manner rotating or changing bonnets when the pad stops absorbing soil.
  6. Allow the solution to completely dry. To accelerate drying, consider the use of an axial, centrifugal, or downdraft air mover.
  7. Vacuum the carpet thoroughly after the carpet dries or at the next scheduled interval.
For absorbent bonnet pad cleaning system:
  1. If using ZipDri Encap TS with a bonnet pad system, mix 8 ounces of solution with a gallon of water into a pump-up, electric, or battery powered pressure sprayer.
  2. Apply mixed solution to carpet and both sides of bonnet pad. Proceed to clean in normal manner rotating or changing bonnets when the pad stops absorbing soil.
  3. Rinse off dirty bonnet in the mop bucket containing the clean water. Wring pad as dry as possible.
  4. Switch to new bonnet as needed and continue process
  5. To speed dry the carpet, buff with clean dry bonnets, turning and changing the bonnet often.
Product Information Sheet: Click here
SDS: Click here
Reactions: Mark Saiger
