Trouble with Hydramaster's Dura-Flow APO
Blue Monarch
Dirk Wingrove
This thing hasn't been working for a couple of weeks. Finally got to pull it out and do some testing. By the way, it's installed on a Boxxer 421.
1. Checked fuse and it appeared good.
2. Tested for power and yes it is receiving power when the waste tank fills up.
3. All connections seem to be good.
4. While power is supplied and I disconnect/reconnect wires, I hear a click, but the motor doesn't spin.
5. Took lower end apart and all is clear, there aren't any obstructions.
Any clues where to go from here?
Doug Cox
Doug Cox
Did you connect it up directly to 12V without anything in between?
