truckmount oil change and type
N
neapolitan
I do it myself and I use Mobil one full synthetic. every 100 hours. What about you?
Art Kelley
I change the oil every month in the Chevy Express (which is about 100 hours on the hour meter) usually with the least expensive 5W 30 I find at Walmart.
Keith
10w-30 every 50 hours or so... Oil is cheap!! I have 3,500 hours on my 25 horse still runs great! I also change the filter every time..
Valvoline for every vehicle and piece of power equipment I own
joeynbgky
Joey
Tm every 50 hours with HD-30 oil....
Van every 3k with valvoline max life oil
steve frasier
steve frasier
HD 30 weight every 50 hours in 450 MAXX
change the vortex oil every 4000 combination of hours and miles
KevinL
Kevin Leach
A friend of mine that designs for Caterpillar told me once that changing brands of oil is bad for an engine. Try to use the same brand every time. That's Valvoline for me.
Doug Cox
Doug Cox
Same. 100 hours is about every three weeks right now.
Brett
Petroleum oils will harden seals and gaskets over time. Good grade synthetics will keep them softer, but can soften hardened seals and possibly cause leaks if you switch from petroleum to synthetics. 50,000 miles is a basic break point for car and truck motors where you might run into problems if you were running one type then switch. Government oil grades type 2, type 3 are petroleum grades, type 4 can be petroleum and synthetic mixes, and the best grade is PAO (Polyalphaolefin oligomers) synthetics. The type 4 group is the problem area because mfgs. can label their oil bottles as synthetics, but lower quality and mixed with petroleum without giving the mixing ratios. Mobil 1 I have been told has been an APO oil for years and I've been running it for about 17 years in my cars and trucks and doing 15,000 mile oil changes. No problems so far. My BMW I had recommended 15,000 mile oil changes done free at the dealers under their maintenance with BMW synthetic. In the manual, if you couldn't find BMW, they recommended Mobil 1. I've been in the oil and grease business for 17 years, but for legal reasons the above info could be incorrect or out of date.
I was changing at 100hrs, going to every 50. 2.5liters is cheap maintenance
I've also a larger filter fitted to the engine
