daniel@procarpet
- Joined
- Sep 7, 2008
- Messages
- 3,797
I have asked this before with no accurate answer. I run my Everest on low and it keeps the solution around 200 at the machine even when it is 30 degrees outside which is perfect for me. My Legend XL on the other hand doesn't run hot at all. It will heat up to 230 but the temp drops off fast and stays around 140-150. I would think this machine should be able to maintain 180-200. The valves are in good order and it does not bypass. I have never descaled it but was told I didn't need to. What should the temp be under normal cleaning conditions? In the summer it runs a lot hotter due to the water temp going to the machine being hotter and the air is warmer. I did have the hx cleaned out and that made a noticeable differerence at first but still not hot enough for me.
