Urine on microfiber
Able 1
Wi
Keith
I used the search it wasn't there... Anyway I have this sectional in the morning that has a large piss spot probably 18 inches diameter. I have cleaned for them before an noticed the spot came back. After I'm done cleaning it it looks great.
So my question is how I can safely use vol. 20 on it, or how should I dilute it.
Thanks for any help...
Royal Man
Lincoln NE
Dave Yoakum
Microfiber is plastic. The problem is likely the cushion not the cover. Clean the foam. (If it can be removed)Submerge it if you have to. Then put it in a plastic bag holding vac cuff inside to pull the water out.
