v belts last forever
if you want your belts to last you need to change them to the made made linked belt the red ones that wood workers use on the table saws i was blowing v belts every week i still have the belts i put on 5 years ago all you do is take a link out the cost more but they last a long time do a search segamenent belts red Link V-Belts called PowerTwist Plus go and see youll never buy a nother belt,
Dallas, Texas USA
Scott;
While they would work fine for driving a pump,
they lack the HP capability for hi-lift blower use.
And they are only compatible with Type "A" & "B" series belts.
Thanks for the heads up, Campusman
and thanks for the link, Randy
this looks like as good a reason as any for their use;
"Other claimed benefits of using these belts include a tool-less link design, easy installation, and linked belts featuring the same cross-section as conventional endless link belts so no pulleys need to be changed etc"
If I understand that correctly, no reason to pull other belts or separate couplers to install a new belt.
Even if they don't last all that much longer, the savings in the PITA factor will be worth it to some of us
hey larry i disagree with you ive had these belts on my blower for 5 years ive had no problem
Shane T
Waukesha, WI
Shane Tiegs
Larry, I too would like to know what engine and blower combination you have. Also what vacumm level are you running at?
24 horse kawasaki roots blower vacum at 12 never never had a problem with these belts they are a v belt they come in a few different sizes all you have to do is take links out no extra work you will pay more but they will last longer than the junk belts i have them on my 68 chevelle i have a 427 big block shift at 7500 these belts are very strong i asked a rep at gates at the summer nationals drag racing and his comment shhhhhhhhhhhhhhhhhhhhhh not a lot of common people know about them he said if all people knew there would be a big decline in sales and they would have to start making them . you guys keep buying the rubber betls you do the math.
Able 1
Wi
Keith
I have two belts that run real close to each other would that be a problem? They look wide are they?
Thanks,
Keith
