V8 fuzion
glenboy
MACOMB MI
GLEN
off white nylon carpet customers wife dropped V-8 fuzion on the rug and they said it is staining but they are doing their best to clean it up,i am goin by there tomorrow to sees what i can do.i picked up a bottle of this tonite at kroger and it says no artificial colors on the label,so i spill some on a tan nylon carpet sq,soak it up and hit it with some 30 vol and over a half hour it went away.has anyone tried this or should i be tryin something safer like cotton care or hydrocide or pro chem odor rescue and claw. shiteatinggrin
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
an oxidizer(sodium perc) should take care of it since its organic, use whatever flavor works best for you. I'd probably rinse it out with a light detergent, and then stain magic afterward.
Shelbyville TN
Flush out what you can. You may need a Water Claw spot tool or similar if there was a lot of liquid. Use the extraction to get the fibers as dry as you reasonably can. Then use an oxidizer, Stain Magic or StainZONE.
