Vac Boosters?
Scott S.
PA
Scott
if i ran a booster that would boost my cfm right? and decrease my dry times?
do boosters use 2 2 stage vacs or 2 3 stage vacs?
what is the power needed to run 2-3 stage vac motors? or 2-2stage vacs?
i have the capability and know how to build one but
would i be further ahead to buy or build one?
anyone got pics of the inside of one
Prattville, Alabama
Drive by my place on your way home and pick mine up. Try it. If you like it, make me an offer.
V's don't need no stinkin boosters!
Here is a link to a 200 cfm booster;
http://www.***************/store/octava ... -4311.html
P
Phoenix Phil
The Steam Brite vac booster sits on top of your portable. http://www.***************/store/univer ... -4832.html
I put it on top of my M12 Mytee with 2 2 stage vacs, checked it with a lift gauge (from Magic Wand) and found it increased my suction apx. 20%. I use a 2 head Rotovac and now have dry carpet in 4 hours instead of 8 plus on loop berber. I use a strap come along to tie it down.
I use the vac booster Odin made me for over 25' 2' hose runs and it is amazing to not have to haul a large 200lbs 'portable' upstairs.
I know Odin gets trashed for being abrasive but his work is very good, and his quality is too.
You could really use his vac booster to extend your truck mounts another 50 feet or so. You can see it in the video of his new electric truck mount.
His booster probably will outlast the truck mount you are using.
I am not a shill but do this part time and have the canceled check from Odin to prove this endorsement is for free.
P
