vac relief which one??
so i figured out my relief is toast...leaking air like a siv...
so bayco, or kunkle??? dont think i am just going to replace the original one....
or is there another option???
Save your money and just get a new gasket for the old airbrake.
86179590 1 DIAPH, VAC REL VLV
Shane T
Shane Tiegs
I've had 2 Kunkles now several years. I'd buy them again.
Total_Rookie
yea why 16???
so got a better picture.....
thats 1 of the things larry should fix...his "click for larger" sux
Joe & Doug;
Ours are adjustable . . .
if you take them off the TM.
Total_Rookie
How is the correct way to adjust? You say off TM, although if it's off how can vac load be seen?
Aero Tech XT
Doug,
Here is a pictre of ours. Stop by antime and check it out. We are just down the road from you in North Salt Lake.
Fully adjustable while installed in your truckmount. 2" MPT
(the picture showes an old zinc plated version. We are currently using a fully stainless steel version)
Reactions: Cleantechsk
Doug,
How much is that Jeremy?
Erik
Erik
When I originally bought the 6008, it had (2) 1/2" Vacuum release valves. They malfunctioned and caused my blower to fail. I replaced it with the Aerotech Pressure Release Valve 5 years ago, it works flawlessly and I never had to adjust it.
