T
The Magician
Sounds like its not getting gas. Is it difficult to install a new fuel pump? 98 Chev. 1 ton van.
BUT REMEMBER don't have that drop lite near the tank as you lower it out.....meAt said:never changed one on Chevy, Jimmy
but if it's in the tank, you'll need to drop the tank
That's the PITA part
once the tank is down, the pump should be about as easy as changing a light bulb
bob vawter said:BUT REMEMBER don't have that drop lite near the tank as you lower it out.....
Jim Martin said:Didn't they put a filter up in the frame....some where around the middle of the van....???
I think I remember one being on mine.........
The Magician said:Thanks for all the tips. called the local Chev dealership and they want $1000 to replace the fuel pump. Unbeliveable
rwcarpet said:The Magician said:Thanks for all the tips. called the local Chev dealership and they want $1000 to replace the fuel pump. Unbeliveable
A skilled mechanic with access to vehicle hoist can probably wrap that job up in 1-2 hours....if nothing breaks. Get her up in the air, drop the tank on a tranny jack. A good flat rate mechanic can make good $$$$ on that job, with the right tools.
