I have a 18 hp Vanguard Engine on my truckmount. The engine starts and runs good with the choke slightly closed. If you pull the chock completely out the engine pulsates. When i turn on the pressure pump the engine slowly chocks out and stalls with a backfire. Does this sound like my carbs are flooding? Could there be something else causing this? Machine is a ProChem Oil Fired.
