Goomer
s]http://www.youtube.com/watch?v=-4wZ13jt5h4s]
http://www.youtube.com/watch?v=3Tf3OX4h ... re=channel
Bob Foster said:So Frank. Not to put you on the spot but why don't you list what you think is wrong with what he did. You have one year in the business and I bet you know about 5 years worth of information if you been paying attention while you've been hanging around here.
No pressure - but let's see what you have learned. I'm sure people will help you out.
danielc said:Ok here is a list of what I see wrong.
1. The carpet looks like it wasn't vacuumed.
2. Possibly no pre-spray was used. Just detergent.
3. The carpet was not scrubed and that carpet needs a good pre-scrub
4. The jets are badly worn and that is the most pos wand I have seen in a while. A cut pile carpet should never streak.
5. A cleaner should work their way out of a room.
6. 1.5 inch whip hose
7. No speaka Engles.
Matt Murdock said:I have a few more classes behind me than you and that don't me squat. Odin actually called me a hack for doing what I was doing in carpet repair the otherday, so that says alot about the IICRC. the learning curve may be adjusted slightly but it depends on the person and what they want to achieve. I speak to guys all the time on the board who want to average $100 an hr and I ask how many jobs you got today 1 $175 and I can do it in an hr and half? What is the rush if it is your only job. I averaged over $800 a day this week(because of restretches and clean) on immediate pays and have some on invoices that may bring it to $875 when I calculate everything. I don't vacum like werner, first off he does it wrong, there is no additional agitation for pet hair etc when you slowly go over a carpet you got to bring it back and forth.
Hate to tell the vacuum guru he has the technique wrong he could save himslef time with a good forward and pullback with a pile lifter then vacuum and prescrub with a real machine
Walrus said:FREAKIN ILLEGALS!
FIND OUT WHERE THEY ARE AND REPORT THEM SO THEY CAN BE DEPORTED!
Matt Murdock said:you are probably correct and I shouldn't have said he does it wrong. I should have said in my opinion. I can guarantee you this sweendog, no one gets carpets cleaner than I do as often as I do. I know I am the best out there
