Vintage rug backing ungluing
Ken692
Boston
Credits
Points
Kenny
Ken692
Boston
Credits
Points
Kenny
I tried cleaning but looks like the dog had his way with it
cleanking
Indianapolis, IN
Credits
247
Points
247
Jordan King
Looks like a modern Indian tufted rug, likely not any older than 10 or 15yrs. Need a picture if the back to confirm.
If the backing is just slightly coming undone around the edges use a hot glue gun to secure.
Ken692
Boston
Credits
Points
Kenny
Don't know what kind of repair this has on the back but it's ugly
Ken692
Boston
Credits
Points
Kenny
This was either at the beach, Or put together with glue. I think 6 pounds of sand came out of it! Not sure how I'm going to attack the yellowing and brown stains, I was going to hit it with baking soda and white vingar.
The Great Oz
seattle
Credits
1,037
Points
1,037
bryan
The "commodity" grade Indian tufted rugs have a lifespan of five to seven years. Past that the adhesive fails and both the backing and edges fall off. If the backing is removed, the majority of bad latex can be removed and replaced with better quality latex to give the rug 10 more years of life. Backing and edge pieces don't matter, unless someone with a no-value rug is concerned by the appearance of the back, as it just adds repair expense to replace.
Cost of cleaning and back repair typically meets or exceeds the cost of replacement. We'd recommend throwing this one away.
Ken692
Boston
Credits
Points
Kenny
Yes looks like this one was at it's end, they just gave it to me and I was going to just use it as a learning experience. I never re glued or backed a rug so if I were what material would I use. And could I do it ??
Ken692
Boston
Credits
Points
Kenny
So do you remove the backing? If so how? or just go over the existing backing material
The Great Oz
seattle
Credits
1,037
Points
1,037
bryan
When you get the rug wet, the cheap latex will turn into putty and the old backing should peel off. Clean as much cruddy latex off as you can. When dry you can get to the new backing.
Ken692
Boston
Credits
Points
Kenny
I did completely wet the entir rug and the back is sold just the edge coming loose.
Not sure but seems grungy
Top
