Vortex 777 clunking noise blower?
AJR
n Al
Whatshisbutt
Problem today starting job. Engaged PTO and a clunking noise from blower area. Turned off water pump and still clunking. I pulled the intake on blower and freely spun blower and no noise and lobes look clean and no Knicks or visual damage.
I went ahead and pulled PTO pulley drive belts and ran PTO solo not connected to blower and sounds smooth. I also hand turned blower solo not connected by belts to either pump or PTO pulley and sounds smooth. Any one have any ideas.
AJR
n Al
Whatshisbutt
Side note. I used truck day before and ran normal no issues. I did grease bearings on grease side of blower and PTO shaft. My problem knocking started next day.
AJR
n Al
Whatshisbutt
I greased the blower day before. Will that cause a clunking noise so soon.
AJR
n Al
Whatshisbutt
Would an out of time issue start out of nowhere or start little at a time.
Erik
Michigan
Erik
Get a mechanics stethoscope and it should reveal the problem. Your pillow block bearings can make a lot of noise under a load. I would reassemble it and listen.
AJR
n Al
Whatshisbutt
Update
It was the blower. Put new one in and all pillow bearings done deal. New belts etc..
Thanks Mike for quick blower shipping
Reactions: Lee Stockwell
Jim Williams
Bynum N.C.
Jim Williams
Just a thought. If you still have the old blower replace the main bearing and save it for later. Then when the bearing in the new blower wears out you can swap it out. You can also have a blower repair shop do it for you.
