- Joined
- Oct 6, 2006
- Messages
- 116,980
My 2004 half AT and half FMI built truck has a 30 pin connector that joins the conduit that goes from under the truck to the bottom side of the control panel
Jim Martin says his was hardwired all the way to each dial, gauge, fuse, sensor etc.. Not mine.
How is your box/panel wired in?
You can see in these pics where I had to hard wire two wires together that had shorted out, this was before I had a local trade me some floor cleaning to take it all apart and solder all 30 or so wires together.
now the unit runs better then ever. No mysterious shut downs, heat or pressure pikes all gauges are happy and not bouncing around at will...
yippie!
yippie!
