Vortex hydraulic heating problems
R
richd8980
Purchased used about a month ago. Not heating up at all temperature gauge was bouncing all over the place before it I lost heat.
Anybody have a Vortex and are they worth having?
Re: Vortex 6008 heating problems
could be a number of things..to be honest to try to trouble shot this with just a few details will be hard....
a few things off the top of my head to start with would be....
check valve went out.
unit is scaled up...
temperature probe went out so it is not calling for heat...( they did not put thermowells on any of theses so I cant see them being accurate and lasting like they should )
First thing I would pull is the temp probe and see if it is damaged..could explane the gauge bouncing ...
6008 IMO is the best vortex out there.....it has most the bugs worked out from the later models and does not have most the complicated BS from the newer ones.......Makes this one a lot easier to deal with....
GeneMiller
gene miller
I'm just curious, are you serious about the vortex being unreliable? What exactly is the problem?
Gene
I agree.
and If I had to buy another today it would be the Aerotech which is essentially a 6008 minus the Xentherm
If Legends continues with the V project you should expect to see the V revert back to the 6008 minus the noise is my guess.
