......W.....T.....H...???
WillS
Will
I was searching for dry compound carpet cleaning videos. Then I came across this video. I could not help but get disgusted.
By the way Will, what do you recommend where to get a couple of boxes of host compound to do a test run?
I purchased a 20LB brushpro compound from an interlink store... so far I had absolutely no success in cleaning any type of carpet with that. It is worth mentioning, that the brushpro compound box was in the back of the chemical shelf covered in dust..... I was trying to find out from the sales people, to see how old that box was. They could not tell me but it was not dry so I assumed, that it will still work. I do not see any good results with this. And that's why I want to give a test run to host sj.
Do you have a Waxie Sanitary Supply by you? We purchase by the 30lb drum which is usually $74.99. They also sell 10lb ones for 20 or 30 something. The small packs I think you can buy at any time of vacuum repairing store, they usually rent out HOST machines for residential customers to use. If neither of those are accessible, call them up: hostdry.com and just ask where the closet re seller is to you. They have a pretty easy to access customer service line.
800-558-9439
WillS
Will
When I first came across these 2 videos I knew this guy wouldn't be in business long. I think the company is actually closed.
Reactions: Old Coastie
