Waltzing with Wanda
Shorty
Shorty Glanville
Does anyone here use the smaller Evolution wand from US Products with their portable machine?
This is the narrower two jet wand.
If so, what do you find good or bad about this wand.
As I head out of being a working Sexagenarian and into a working Septuagenarian, I'm looking at lighter equipment for my arsenal.
Ta,
:mrgreen:
Brian R
Brian Robison
I played with it when it first came out and it was just way to light weight.
It didn't seem to get into the carpet fibers unless you pushed down on it......Which would make it harder to use and defeat the purpose of the wand.
That was about 6 years ago or so.....So who knows now.
Shorty
Shorty Glanville
Well then, what about The New Bentley™ "Feather-lite" # 8312
The Bentley™ models feature:
• Durable carbon fiber construction
• Light weight--models start at 8 lbs.
• 2” vacuum tube
• Specially designed vacuum head—allows for maximum CFM
• Four adjustable solution jets
• Optional swivel head allows the wand to run almost completely flat—clean under furniture without moving it
• Ideal for truckmounts or high-powered portables
• Ideal for residential or commercial cleaning
• Optional swivel head for supreme mobility
• Easy touch valve and ergonomic grip
• Great for removing stains in high-traffic areas
• Stainless steel spray manifold for high flow solution delivery
• Available in a 12” or 14” cleaning head for maximum coverage
Specifications:
M.S.R.P: $539.00 (Plus S/H)
Warranty: Limited lifetime warranty
Cleaning path: 12"
Body: Carbon fiber
Style: S bend wand
Tube diameter: 2"
Jets: 2
Rated to: 3000 PSI,
Wand weight: 8 lbs.
Wand height: 57"
Shipping weight: 15 lbs.
Shipping Dimensions: 12 1/2" x 11" x 68 1/2"
Cheers,
Shorty.
