harryhides
I applaud ANY testing being done in an attempt to help all of us both carpet cleaners AND manufacturers to come up with improvements of many kinds. Testing as described above with gauges is the simplest but still will not tell every carpet cleaner what is the best unit for each one of them.
There are personal preferences and abilities to repair units, price, weight and ergonomics etc.
I will say it again, I did a lot of work in an attempt to get fair, reliable and repeatable results at MB4.
But it rained every single day of the event and through some mis-communication, the carpet samples that had all been laid out to dry of the last evening of the event were thrown around and stacked up on each other early in the morning and so many were still damp when they were weighed for the last time. There was no tomorrow because everything HAD to be cleaned up and removed that afternoon.
The end result was that some samples actually weighed MORE after cleaning than they did before they were cleaned because the weight of the soil removed was less than the weight of the water remaining in the wet carpet.
Brand width # Jets Jet capacity Glide Pre-clean gms Post-grams Diff pre-dry Post-clean Diff
Evolution 16" 6 4-1.5 2-02 Yes 1914.5 2069.6 155.1 1906.8 ........................- 7.7 gms
Bentley 12" 4 1.5 Banana 1917.4 1977.3 59.9 1897.6................. -19.8 gms
PMF 802 12 2 3 Hybrid 1944.5 2074 129.5 1944.9....................... + 0.4 gms
Butler 14 5 3-01,2-1.5 None 2026.5 2220.0 193.5 2024.3 ........................ - 2.2 gms
White Magic 12 2 0.02 None 1933.3 2086.1 152.8 1924.0................ - 9.3 gms
Prochem Ti 14 6 1.5 Hybrid 1932.3 2022.9 90.6 1909.3 ................ -23.0 gms
Prochem Quad 12 4 1.5 Hybrid 2061.8 2216.9 155.1 2050.0 ........ -11.8 gms
Green Horn 12 4 2 Holed 1921.2 1998.9 77.7 1912.4 .......................- 8.8 gms
Prochem Evererst 650 @400
So, unfortunately the above tests were flawed and the results are simply not worth publishing and I certainly do NOT stand behind them.
I wish the testers lots of luck and hope that they will have lots of useful results to post. But if some testing equipment turns out to be malfunctioning, I for one will not beat the testers up over it.
So all of you horrible people should just shut up, once and for all and try to get over it.
