Jeebus Larry- I gotta make hay while the sun is a shinin'. And it's the REAL steelhead season, when true fisherman work their art.
Geez Doran, where to start. Look for a 500 psi, 2 three stage vacs. the numbers will confuse you, but they all squirt and suck - look at customer service. Ed Valentine gets a rough ride around here, but when I lost everything in a fire, he gave me a smokin' deal on some replacement equipment and some of the best after care and service I've ever seen in my years in the business. I inherited a new Ninja
Warrior and found exactly the opposite with Century 400/
Prochem/K'archer,, both with machinery and chemicals. I've never bought from John at Mytee, but it seems he has great after service as well. I do like John's new machine with the
General pump and bad ass vax, but that's not in the cards right now.
Don't bother with internal heat. It cooks the other components up quickly. Instead, look at the Kleenrite Heatrite and go for the 2 corder. An AW29 wand or equivalent clone works great, try downsizing the jets to a 3 flow for more impact and faster dry times, as well if you use an inline heater you'll get a good long blast of hot.
Pumptec pumps will last a year under heavy service. They need to be rebuilt every 500 hours, you can't use powder detergents and I'm not a big fan. However they do have low amp draw. Aluminum is not a good choce for a pump head, but it is what it is.
You'll always get 2 good circuits in the kitchen, one on the wall, usually a 20 amp and 15 on the stove. Washing machines are normally a separate circuit as well.
Get a system to scrub the carpets - it makes those traffic areas just that much better for the extra work. Buy a good quality vacuum - very important.
We've got a huge high rise area here and I focus on that, but I do lots of ground level as well. My customers, most of whom came by referral, don't give a fat rat's ass about my equipment, they just want a good clean.
Hope that helps, if there's anything I can answer or help with, PM me.
