Becker
Thanks to Rob Sutherby ( Sticky ) I looked into Street Atlas USA 2009 Plus.
Bought it form Costco for $39.95
The program takes a little while to learn, but once ya figure out the commands you can easily select streets, then transfer the address and phone data to a save window.
The save window will only export 1000 addresses at a time.
So, here is what ya need to do after you have saved all the info to a text file.
You need to import it to excel.
Once you have the spread sheet up, highlight all the addresses ( only the addresses )
The under the home tab click on "conditional formatting"
Highlight, duplicates.
Excel will highlight all the duplicates so you are not mailing to the same address.
Believe me, some houses have 4 or more listings.
WOW, very quick!
I'm building a data base of 10,000 homes in select hoods to rotate mailing to.
WOW, very quick!
