Water damage stains on CGD
ACE
Yea, I’m thinking I’m mostly looking at mineral deposits. I like the citric acid and releasit idea.
boazcan
I have used several times on multi story condo hallways with laundry rooms on every floor. Most of them at one time or another leak into the hall and leave a ring. The 30 vol will help. You can also mix 6-8oz of releasit with 6-8oz of 30 vol also. I have used both citric acid and 30 vol combos successfully.
Willy P
Willy P
Potassium metabisulfide.... Or metabislfite......
Ah heck- potato whitener. Get it at the grocery store.
(Another in the series of Willy's Cheap Thrills!!!!)
ACE
Reducer, Is that what you would try first Willy? Potato whitener huh? That’s interesting. I have never known how to by reducer locally. I guess I better decide whether to start with a reducer or oxidizer as they are opposite ends of the spectrum.
Hoody
Steven Hoodlebrink
Years of Experience
20
oxidize first, then reduce
ACE
It turned out great. I sprayed the bad areas with 30-40 Vol from a small pump sprayer, pre-sprayed with PB, extracted with acid rinse and post padded.
We appreciate it when those that ask a question on a problem have the courtesy to come back on and tell us how it turned out.
Thank you for doing just that.
Lee
