water in oil
406
any tips on how to remove water from my pump. it was slowly leaking water into the oil, i have fixed the problem but still have a slight water residue in the fresh oil. thanks
406
greenie, yes i did just that but, the clear cover still looks slightly milky. i will drain and refill several times in the coming months. just wondering if there is a better way to remove all the moisture. im wondering if putting varsol in, letting er run a few mins and the draining and refilling would do the trick, or possibly sticking my vac hose on er and sucking it out?
If it is on Water pump and it is a little milkey it wont hurt . green guy probably hit on the head.
