water in oil
4
406
any tips on how to remove water from my pump. it was slowly leaking water into the oil, i have fixed the problem but still have a slight water residue in the fresh oil. thanks
4
406
greenie, yes i did just that but, the clear cover still looks slightly milky. i will drain and refill several times in the coming months. just wondering if there is a better way to remove all the moisture. im wondering if putting varsol in, letting er run a few mins and the draining and refilling would do the trick, or possibly sticking my vac hose on er and sucking it out?
The Cleaning Artist
run for a few min then change repeat till all is gone
If it is on Water pump and it is a little milkey it wont hurt . green guy probably hit on the head.
