Jul 13, 2008 #1 C Curtis Pennington Member Joined Jul 12, 2008 Messages 1,537 Is the PSI adjustable? ....I saw it was rated at 1200 PSI
Jul 13, 2008 #2 packfancjh Member Joined Oct 22, 2007 Messages 2,551 Location Sparks NV Name Chris Hagen yes it is adjustable
Jul 13, 2008 #4 packfancjh Member Joined Oct 22, 2007 Messages 2,551 Location Sparks NV Name Chris Hagen as low as you want I believe.
Jul 13, 2008 #5 Bill Soukoreff Member Joined Sep 3, 2007 Messages 961 Location Victoria, BC Name Bill Soukoreff 0 to 1200 PSI. Great pump. Had over 1000 hours on mine before rebuild. Easy to rebuild. Puts out some serious GPM. More than some TM pumps. Mine draws from a tank or direct. Also, I put a gauge on mine.
Jul 13, 2008 #6 Scott S. Supportive Member Joined Feb 3, 2008 Messages 3,234 Location PA Name Scott do you use it for pressure washing or for tile and grout cleaning?
Jul 13, 2008 #7 Bill Soukoreff Member Joined Sep 3, 2007 Messages 961 Location Victoria, BC Name Bill Soukoreff I use it on upholstery, carpet and T&G. 1200 PSI would be pretty light pressure washing.
