water out of exhaust
cub234
Steven D'Aquila
water is flowing out of my main exhaust on a Prochem Legend. Unit froze a few times but this is a new one. Looking for a diagnosis. thank you
your waste tank was probably near full and maybe your float switch has failed.
your lint filter/trap might also be clogged.
wash the inside if the tank and try to remove the lint that might be interferring with the float switch.
Its the exhaust exchanger that is close to the door.
Pull it out and just use the other one. Temps will be cooler but you can try to repair the old one. Wish I knew what car model the heat exchanger came out of.
cub234
Steven D'Aquila
Looking to take out the heat exchangers soon and look
cub234
Steven D'Aquila
If it isn't your waste tank water and you have the model with the three heat exchangers, you can check which of the exchangers is leaking. Bypass one at a time by swapping the hose connections.Thank you for the response.
cub234
Steven D'Aquila
Thank you for the response. I will try. this thing is over 20 years old. I need to rip her apart a bit
cub234
Steven D'Aquila
Thank you for the response. not the issue but thanks
cub234
Steven D'Aquila
Thank you for the response. I think you are right on the exchanger
