water out of exhaust
Chandler Arizona
Justin Johnston
water is flowing out of my main exhaust on a Prochem Legend. Unit froze a few times but this is a new one. Looking for a diagnosis. thank you
What Ron said.
Clean water = popped heat exchanger
Dirty water= bad waste tank float, or foam.
But if it froze a few times, I would lean towards a popped heat exchanger.
San Francisco, CA.
your waste tank was probably near full and maybe your float switch has failed.
your lint filter/trap might also be clogged.
wash the inside if the tank and try to remove the lint that might be interferring with the float switch.
MA
Doug B
If it isn't your waste tank water and you have the model with the three heat exchangers, you can check which of the exchangers is leaking. Bypass one at a time by swapping the hose connections.
Ne
Its the exhaust exchanger that is close to the door.
Pull it out and just use the other one. Temps will be cooler but you can try to repair the old one. Wish I knew what car model the heat exchanger came out of.
cub234
Willowbrook Illinois
Steven D'Aquila
Thank you for the response. I think you are right on the exchanger
