Aug 27, 2008 #1 steve g Member Joined Oct 8, 2006 Messages 2,316 Location herriman, UT Name steve garrett how do you check to see if your high pressure water pump is putting out the volume that it should??
Aug 27, 2008 #2 G Guest Guest A 5 gallon bucket.Hold down trigger for one minute, then measure,probably without jets. Kevin
Aug 27, 2008 #3 packfancjh Member Joined Oct 22, 2007 Messages 2,551 Location Sparks NV Name Chris Hagen fire up the machine put an open flow on the end of the hose (open male or female fitting on end). Have it flow in a bucket for one minute and it should compare to the gpm rating on your pump. If it doesn't you may need to do a valve kit for it.
Aug 28, 2008 #4 Dolly Llama Number 5 Joined Oct 7, 2006 Messages 30,635 Location North East Ohio Name Larry Capitoni packfancjh said: If it doesn't you may need to do a valve kit for it. Click to expand... or thoroughly descaled or inlet restriction as me how I know ..L.T.A.
