As Hot as my truck gets me.. lol.. No Salsa package so Our doesn't get much hotter than 210 or 220 ATM. So I open it all the way regardless of material unless we are doing rugs and I know the fibers might be damaged by slitghly higher heat.
My salsa CDS gets up to 220-230 while cleaning. But often times it's around 200 ATM while cleaning with my greenhorn cause it takes a while for the blower to get hot....once it does 220-230 and a popping valve and a hot wand for sure.
My next TM will have way more heat. I want 250 ATM sustained for 2 wands at 15 flow each.
ok anyone who cleans at under 200 and says its just fine....has never cleaned with the higher temps...
you get in the 230-250 range, now we are cleaning some carpet...
240ish here...burner has a 250 switch in it, and i have measured out 100' and it hits the 240 before it shut off...so i guess between 230-240....and that mutha is a hissin and spittin like crazy
210ATW when it's 30 degrees outside. I imagine that could easily be 220-240 ATW when it's 90 degrees outside, but I could be wrong. Only tested it in the winter, and it didn't seem as hot as summertime
We were running 400 psi, 9 flow with stubby's from GG, now that we installed the turbulators,... we tried setting the machine at 245 degrees and it actually ran almost 300 non stop. (same set-up)
