Contemporary Carpet Clean
- Joined
- Oct 2, 2007
- Messages
- 336
- Name
- R.J. Povio
cleaned a house yesterday and half of the carpet was a low pile (almost like a low pile plush commercial grade carpet) that was about 22 years old.  Then in the liv and din rms there was a really thick also 22 year old 100% plush nylon carpet.  After cleaning all the carpet while doing the final walk through with the custy the low pile carpet had numerous waves/bumps in it. Ive had this happen a few handful of times on this exact carpet before.  I used HWE with water temps of 200-210 degrees and about 500 psi and double vacd.  The custys were elderly so i wanted to make sure the carpet dryed asap!  My experience has ALWAYS BEEN THAT THE BUMPS/WAVES GO AWAY UPON DRYING.  Ive never had to call a guy in to restretch the carpet ever on either commercial or residential jobs (and ive had it happen on comm jobs before too).  The thicker 100% nylon carpet in the liv and din room DID NOT WAVE/BUBBLE AT ALL AND I CLEANED IT THE SAME WAY I DID THE LOW PILE CARPET.   My question is why does this happen? and how do i explain it other than this happens on this type of carpet and it will go away when it fully dries?  Is there anything i can do to prevent this from happening in the future?
Ive noticed that this happens MOSTLY on older (seems like 20 yrs or older) carpets rather than newer carpets is there a difference in the fibers/backings/padding from 20 yrs ago to todays products?
Also custy has used Chem Dry before and never had the wave/bump effect on the carpet when they were done. So i have to say its either from higher heat and or higher pressure or a combination of both. Thank you for any feedback and or similar experiences.
