What causes this?
Bill Soukoreff
I posted about this before but did not have pictures. This is a new carpet about 6 months old and has never been cleaned. It is in the basement of a house and has nothing to do with lighting. The customer says they have never used any cleaning agents on the area. What are the possible causes?
http://gallery.me.com/billsoukoreff/100051
Sometimes called "fume shading" as found around floor registers on gas systems. Not the same as the carbon-based filtration soiling.
H
harryhides
When traces of combustion gases combine with trace amounts of Butylated hydroxytoluene off gassing from re-bond underpad the result if yellowing and many types of textiles.
sweendogg
David Sweeney
It can also be excellerated by having tufted rugs or latex/ rubber backed rugs on the carpet. These will all off Gas and cause color discoloration as well.
C
Contemporary Carpet Clean
tell custy to put some nice ceramic tile to match the fireplace insert a couple feet out from fireplace.....problem solved and it looks just as good if not better.
Brian R
Brian Robison
Like Bathrooms, I never understood why anyone would put carpet there.
Brian H
Brian H
There is an area that is unaffected directly in front of the base of the fireplace out about 2 inches. That seems to correspond with height of the brass base of the firepalce surround.
Given that the fireplace is on, is it possible that what you are seeing is merely a reflection of the glass and/or light cast from the fire itself?
I would hold a tarp or something large in front of the fireplace to see if the "spot" disappears!
Bill Soukoreff
No, it not a lighting problem. I am sure Harry is right. The carpet retailor is waiting for the sales rep to do something. We have a lot of this combination up here in Canada. People like carpet and gas firplaces in their basements but this problem is still very rare.
