What could go wrong?
S
soundguy7440
Wow, looks like i should've waited on getting that porty...
jack zerkie
Yea lots of residue if done enough times then call the carpet cleaner. If she would use the cleaner first in a spray bottle and the use water in the bissell to rinse and extract they wouldn't need to call the carpet cleaner. Thank U bissell for your help.jz
Ron K
You guys laugh but with a little technique and common sense you can do a pretty good job with the
Bissel CRB brush uprights. Try it you might not need a truck mount.
I get about 1hour dry to the touch with a 20" box fan.
Nylon.
Truckmount makers should be very afraid if Bissel ever decides to make a truckmout. I'm sure they wouldn't put all the BS like LED lights on their machines.
Nylon.
What I said! But that little 15 ft. Cord is a killer😬 Oh, is 15 ft. stretching it?
