Re: What do you think Stockwell, would you buy one of these.
Jay DeLaughter said:
Its a very nice machine, But its a steel frame, needs more bracing on it, uses mufflers for silencers, and where is the stainless? I can get a all stainless EZ3047 for $10,500.
Thanks. It's a steel, powder- coated frame.
As for bracing, you need to look closer. The frame is 2" square tube and 2" x 1" channel. Both the deck for the blower and the engine slide plate are 1/4" steel, also powder- coated. The blower plate is 3/16". The deck, engine and blower plate are all broken on the front and back (and sides, for the blower plate), for increased rigidity.
No 1" square tube is used anywhere. Not that 1" is "bad". But 2" is simply much stronger and more rigid.
Mufflers are a plus, in my book.
I suggest that you buy an EZ, then. I've been asked more than once recently to design an "el Cheapo" system to compete with EZ, ChemTex and AmTex.
I simply won't compromise.
Building systems has some things in common with cleaning carpet for a living. Mainly, you can charge enough to ensure that there's enough profit for company growth, or not.
If you don't charge enough, you're going to have to compromise somewhere. That compromise may be in the form of having a second job to take up the slack, which means that your availability and therefore, your dedication, will be limited, or in cutting corners in some work- related way. But for me, this is all I do (I don't clean carpet on the side) and I'm not going to put 10 hours of labor into something and be satisfied to get $20 and hour for it.
Some people are. Just like some people will clean a whole house, "regardless of size", for $79.
