What have we got here?... 2015 Sapphire Pro 1200 unveiled..
if you have a good filter box...that is the best and most simplest way of doing it...
with out a filter box then your going to want a devastator .........
I did not know that they had filter boxes or or I would have gotten one for my 570.......
"Rob Bighead"? This poster has to be either T-EM-F Rob or Mikey in drag.
Lefty724
E
That thing looks awesome!
Are they going to be available for older Ford Econolines as well?
Or is this just for Chevy vans.
Is it designed to go in a box truck? Is there a larger waste tank available?
Aranda should be along shortly to answer those fine questions.
(and no, you will not be getting a free unit because you are a Mikey's Board Moderator)
Zee
I'd be a lot more interested if they built this for the new euro style vans... Any plans for something like that?
Reactions: Cleantechsk
the drive system will be adaptable to other alternative vehicles at some point.
For 2015 it's all GMC I believe..
Rick will be along shortly with all the answers and more
Sapphirerick
Rick Aranda
I'll start with the basics as I'm using my cell phone and it's a little difficult to go back and forth. It is a T408 Heliflow blower. This is the same blower we use on our 570.
The water pump is the Emperor series By General pump. 5.6 gpm. Max psi is 1200 psi.
The clutch we use is rated at 120 ft lbs of torque.
Waste tank capacity is 80 gallons at shut off. There are two ports available to add an APO if needed.
Ralph Pastorelli
My old 1200 had all day water and waste tanks of 120 and 140 gallons will a bigger water tank be a option?
Are we too soon to look at options yet?
Our Butlers have the optional 210 is there any thought to offering a larger recovery for a box truck install?
