B&BGaryC said:Mytee M12
vincent said:B&BGaryC said:Mytee M12
The only reason I won't buy a Mytee (sorry John) is because of those JUNK pumptec motors. This porty will be on site and used alot.
The masterforce looks nice with the right features. US products is out of sight on price.
Willy P said:vincent said:[quote="B&BGaryC":2nl28w00]Mytee M12
[/quote]rotovacguy said:Willy, this is a pic of my main unit. It's a John Deere badged unit, made by Mi-T-M out of Iowa, with a General pump. I also have the "little brother" to this unit, it also has a general pump (not quite as high quality as big brother...but still kicks ass), albeit with less flow and pressure. Picked both up for about $1300 total. Fookin' Pump"crap" wanted about a grand for ONE of their pos units!
It just hooks to a standard garden hose, with a quick connect coming off for the pressure side. Nice handle makes carrying the beast (80+ lbs!) easier. You can also get this model mounted to a cart, but that was too bulky for my liking.
John LaBarbera said:Mytee has literally used thousands of Pumptec pumps, with very little problem. What we have found that if the unit is plumbed poorly, though it will work for a time, but it will be damaged in the long run. It is not fair to blame Pumptec for a "manufacturer" who plumbs it incorrectly. The pump didn't become the standard by having poor quality.
Never-the-less, if your minds are made up, let me ask you guys this. How do you go about changing the oil on a General inside a porty. (btw, I think General pumps are very good pumps) The other problem with an oil bath pump in a porty is if you lay the unit down on it's side it will leak oil. These are a few of the issues that a manufacturer deals with that make it difficult in choosing the "best" overall pump. We used a Cat pump for a while with an oil bath and that oil leaking when laid down was the biggest complaint, number two was the cost of a rebuild kit.
In all fairness, setting aside your preference for a minute, either pump needs to be maintained. One you change the oil the other you change the bearing. Time and cost are probably similar.
I'm very interested in your constructive comments.
rotovacguy said:John LaBarbera said:Mytee has literally used thousands of Pumptec pumps, with very little problem. What we have found that if the unit is plumbed poorly, though it will work for a time, but it will be damaged in the long run. It is not fair to blame Pumptec for a "manufacturer" who plumbs it incorrectly. The pump didn't become the standard by having poor quality.
John, I use nothing but external pumps, so laying it on it's side is not an issue for me. Living here in Wisconsin, it's too much of a pita for a POG, like myself, to have to wheel in my Mytee every night. With an external, I can leave the big green beast in my trailer, and just carry in the pump to prevent freezing. Plus, when our humid summers start up, the last thing the base of my machine needs is more heat. Keeping the pump separated from the vac motors helps tremendously.
I've heard some on here say they have had excellent luck with Pumptec....glad to hear it. I just can't say I've had such luck with them.
John LaBarbera said:rotovacguy said:Willy, this is a pic of my main unit. It's a John Deere badged unit, made by Mi-T-M out of Iowa, with a General pump. I also have the "little brother" to this unit, it also has a general pump (not quite as high quality as big brother...but still kicks ass), albeit with less flow and pressure. Picked both up for about $1300 total. Fookin' Pump"crap" wanted about a grand for ONE of their pos units!
That is very nice. I looked up the smaller unit earlier that you said was $400.00. That was a very good price too. Is that actually a General on the smaller one? The larger one looks very good, and for the price I can see that being a General pump.
Willy P said:John, in a nutshell:
Flow- That's a given
Impact- Key the wand on a Pumptec, key the wand on a General or Hypro. Significantly less pressure drop. The only way to get the impact out of a pumptec is to choke down the jet size.
Longevity - 5 pumptecs in the same time as one General.
Brass vs. Aluminum - I'll take brass every time.
Yep- you don't lay them on the side, you have to change the oil every 6 months and they're damn heavy. They're not for everybody, but for a more demanding and seasoned professional, they can't be beat.I know what I want, but nobody builds the tank I envision with a General and quad vacs. I had one once, but it was lost in a fire.
John LaBarbera said:[quote="Willy P":36mfdjsq]John, in a nutshell:
