What UV light are you using?
Zee
Cobb's UV light. It's awesome.
Thousands of dollars worth of help for us.
Reactions: dealtimeman
Zee
I took Cobb's light to interlink and check them side by side... Still would pick it over the interlink light.
Zee
I bought 2 of those $240 lights.
Using them every day... To my customers' displeasure.. Because it's always revealing something.
Scott S.
Scott
This video says alot about cobbs light. distance, and its not dark in the rooms.
Scott W. Do you have a video of your light in use that you can post us a link on?
Russ T.
Russ Terhaar
I won Cobb's light in a raffle in Clearwater. It's excellent. Very well made and works in rooms that aren't totally dark.
It's the one you want.
Charlie Lyman
Charlie Lyman
I bought the cheap light off eBay for $23. Works good
Lights were on in this room.
K
Kellie Hiler
Honestly, I use the $50 one from Interlink, it's small and works in brightly lit rooms. It works on 3 AA batteries and I love it.
Reactions: J Scott W
Zee
It's like wanding out a job vs rotary extracting.
(The rotary would be a nicer UV light)
Kellie, with Cobbs (expensive but very worth it) light you can inspect quicker and do spect larger areas as the beam for the lack of the appropriate term is so strong you can see the pee in daylight without glasses and over greater spans than the small patter most lights project.
Makes showing customers especially a more shocking effect.
K
Kellie Hiler
If you could spend only $50 on a UV light that can be used in extremely brightly lit rooms, is made of good quality, why would you not get it?!
Zee
My point was, that you can do a decent job just wanding out a carpet and not really knowing how much better a Hoss or Rotovac would do.
That's my experience with the lights. Until I got Cobb's light, I thought I did good with a cheaper light. But if you are satisfied with what you got, then it's all good.
Reactions: Kellie Hiler
Larrys lights are proprietary as Larry buys the components and then manufactures the light using his own "led" ( Larry can correct me if I am wrong or using the incorrect terminology).
And he picks the frequency of the light specifically for us.
