L
Larry B
Took a job without reading the fine print.
Have a job coming up that we cant use HWE or any kind of cleaning that would require a pad to be spun on the carpet. Moisture and static are the 2 biggest problems for this building. The doors can also not be held open so even using the Vac hose for anything is out of the question.
What do you think would work best on CGD but at the same time would be LOW MOISTURE and not require the use of a pad?
Encap with a encap machine?
I dont care what your idea please post it. This job will pay for any equipment we purchase to use so give your input.
