everfresh1
I've tried many different brands none seem to really work that well which is the best.
Rightie Tightie said:coffee is always going to be hit and miss
anything like Haitian cotton cleaner with sodium metabisulfite or like cleaners only problem with this chemical
it will set off an asthma attack with me and could with some of your customers
have had good luck with home made remover H2O2 and ammonia
some time even fels naptha will work
no two cups of coffee are the same decaf is the worst to remove
and not to forget by the time you get to the stain the customer has used reslov woolite and oxyclean and what ever first
TimP said:Also remember that a coffee stain isn't going to go away in a matter of seconds. It takes time for the chemicals to alter the stain at a molecular level. Wet the stain with the remover and wait till it dries.
everfresh1 said:TimP said:Also remember that a coffee stain isn't going to go away in a matter of seconds. It takes time for the chemicals to alter the stain at a molecular level. Wet the stain with the remover and wait till it dries.
Yea, Maybe thats the problem the stains are never completley dry when I leave hopefully they do dissappear eventually.
