Rob Fairfield
- Joined
- Jan 15, 2013
- Messages
- 174
- Name
- Rob Fairfield
Here is a video of our latest product. Polish Pro,the ULTIMATE crystallizer. This crystallizer requires no steel wool and is a very fast, efficient way to maintain the polish on marble, travertine, limestone and terrazzo floors. It's also a quick and efficient way to remove etch marks (water rings) from marble vanities or "POP" the shine on concrete counter tops.
While no crystallizer equals the color and reflective values that Diamond Renew, 5X or other powders do but it does have it's place in our industry. Commercially it is much more popular because its fast, quite, inexpensive, and public areas don't have to be closed down. Not offered residentially as much unless the customer can't afford powder polishing.
Chemical cost is less than $.01 per square foot. One man on a 175 machine can do 400 to 500 square feet an hour, a high speed burnisher can almost double the square footage. Add your labor and your total cost is nowhere close to $0.10 per square foot. Going rate for crystallizing should be $0.90 to $1.25 per square foot.
If you currently use Monkey, Spinergy, Twister or other pad systems and don't chemical polish at the end, try Polish Pro and see what happens.
Polish Pro has properties that harden the surface making it harder to damage and in most instances adds to the slip resistance.
Polish pro has also replaced the maintenance crystallizer in the process for polishing granite countertops.
Contact me if you have any questions
http://www.youtube.com/watch?v=4-77jAjCOPM
