I like Motion Industries for mechanical parts, Doug...they are usually extra helpful in guiding you with the correct choice for your needs! Here are the 2 closest to you...
Depends on the sheave size, a 7 inch B sheave will only transfer 11.67 hp per belt at 2850rpm, you need 33hp, so that means 3 B belts or 2 5vx belts (29.56 HP per belt with a 7" sheave)
I ordered an 8.35 in. to stay in proportion with the engine pulley. The Prochem pulley for an Everest only has two grooves, so it better work. Of course, I doubt it could work any worse than the Powerclean setup.
