Where can I find a sheave??
Doug Cox
Doug Cox
I'm looking for a 7-8" sheave for a Roots 59 blower. Any suggestions where to start looking.
Doug Cox
Doug Cox
How do I match that to the shaft on the blower?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
How many grooves needed?
Anyway, find the sheave you need and it will note which bushing type to use. Then find that bushing that fits the shaft size.
The 59 has a 1.125" shaft.
I had a guide that explained it more in depth (bushing types, installation, etc) but I'm away from my PC
true...and you can always get the part number off grainger and search around
I chose grainger because they have better pics and you can usually find one nearby
Doug Cox
Doug Cox
Thanks guys- I think I can take it from here. The help is appreciated.
Jimbo
I like Motion Industries for mechanical parts, Doug...they are usually extra helpful in guiding you with the correct choice for your needs! Here are the 2 closest to you...
  • WI22 - MOTION INDUSTRIES
    2302 BELOIT AVENUE
    JANESVILLE, WI 53546
    Phone: (608) 754-4199
    Fax: (608) 754-4639
    diane.hinkel@motion-ind.com
  • WI08 - MOTION INDUSTRIES
    W229 N 1687 WESTWOOD DR UNIT C
    WAUKESHA, WI 53186
    Phone: (262) 896-3880
    Fax: (262) 896-3890
    fred.przbelski@motion-ind.com
Shane T
Shane Tiegs
Shouldn't you be able to just replace the outer portion of a split taper sheave?
AshleyMckendree
Ashley Mckendree
for a 59 i would suggest a two "B" groove pulley
Depends on the sheave size, a 7 inch B sheave will only transfer 11.67 hp per belt at 2850rpm, you need 33hp, so that means 3 B belts or 2 5vx belts (29.56 HP per belt with a 7" sheave)
Doug Cox
Doug Cox
I ordered an 8.35 in. to stay in proportion with the engine pulley. The Prochem pulley for an Everest only has two grooves, so it better work. Of course, I doubt it could work any worse than the Powerclean setup.
AshleyMckendree
Ashley Mckendree
How many grooves and what sy
AshleyMckendree
Ashley Mckendree
Stupid tapatalk, how many grooves and what style belts did you go with?
Doug Cox
Doug Cox
Both pulleys are in the 8" range and I hope to stick with BX Predator belts.
