W
White-Magic rebuilder
Got it narrowed down to this, main seals in 5 CP cat pump. So where can I find them?
Thanks,Rob.
Thanks,Rob.
Steve Lombardi said:when you change seals in the 5cp pump use the hi temps seal kit. Cat pump part #31638. The cat pump valve kit part #30821 (3 check valves come it the kit. so if you want to replace all of the you need 2 kits.)
No special tools are required to rebuild the 5cp pump. All you need are metric tools.
Steve Lombardi
All-Care Dist.
Dont mess around with these Distributors They want to much ,you can find them at www.dultmeier.com look for the power wash equipment & supplys. they list all the cat pumps and parts list.or call them at 1-800-553-6975.Lots of good stuff great prices. Postal Dave.Got it narrowed down to this, main seals in 5 CP cat pump. So where can I find them?
Thanks,Rob.
Steve Lombardi said:Rob,
How did you make out with testing the individual parts ? (volume test of the pump and checking out the unloader)
Steve Lombardi
All-Care Dist.
depending on the rpm's that volume may be correct for that pump, check your inlet filters and regulators if you have them for restriction. Also check out the unloader ball, spring and internal check valve for damage.
Steve Lombardi
All-Care Dist.
