Which Sapphire TM would be the better Dual Wander..
M
MB Auctions
The 870ss with its 410 blower or the Pro1200 with it's 56 blower
I wonder if Rick Aranda has done any hose run testing on the two..
BLewis
Billy Lewis
Good question, I would like to see test outcomes on this also.
thanks Dan
Everest Hp 650 w/ 100 Gallon Waste Tank
This simple to maintain truck mount has been engineered to meet the needs of even the most discriminating user. Hyundai 1.6 liter 68 h.P / 3600 rpm engine, 650cfm triflow blower, general 5.5gpm pump, patented heat exchange system eliminates bypass to the waste tank. True dual wand operation. Auto chemical prime. High pressure circuit: up to 3,000 psi for pressure washing. 100 Gallon waste tank
870SS LIQUID COOLED HIGH PRESSURE WITH HEAT
Model- 870Ss High Pressure Truckmount
Powerplant- Ford Tsg-416 4 Cyl. 63 Hp 1.6 L Liquid-Cooled Engine Operating at 2600 Rpm
Vacuum Pump- Gardner Denver 410 Trilobe Blower 700 Cfm 16 Hg
Solution Pump- General 2500 Psi, 5.6 Gpm
Waste Tank- 90 Gal. (340 L) Tig-Welded 3/16 in. Marine-Grade Aluminum. 75 Gal. (283 L) at Shutoff. Option: High Capacity Tank 120 Gal. (454 L) / 100 Gal. (379 L) at Shutoff.
Same blower, yet 50 CFM difference..?
I wish Lance would put his up against the Waterfall's Vortex to do a comparison.
I know that I can put out two 150' runs off my V and still get more scream from the wand than a single run off my 4.8 blower.
Dan
Dan
thanks Dan
[/FONT][/COLOR]
I wonder if its a plumbing difference and if the CFM was truly tested the same.
Bill Bruders
Bill Bruders
The 870 is your everyday duel wand slide in Champion. The 1200 is a leading design direct drive that can take on duel wand opportunities. How's that for an answer :-)
Lance Golden
Lance Golden
Mike,
Kemp and I would be happy to... However, neither of us has a CFM meter.
Although I have "suggested" to Kemp to come out and clean with a "real truckmount"
For some reason, he just laughs... IDK...
Dan
Dan
that sounds fair.
Todd
How many Pro 1200's are out in the field if you don't mind me asking Bill? I would love to have one of those someday…What are you plans for the new vans that are coming to the market? I don't think a direct drive will work with most of the newer vans getting ready to hit the market soon. Hopefully chevy will keep their cargo van as it is for a while.
Bill Bruders
Bill Bruders
Since all of our competitors use this board (as well as others sorry mike) to gauge new idea interest as well as find out who's buying what I can't really answer the number in the field question. I can tell you that we are thrilled with the sakes results of the updated model we sell versus the WM model we purchased. I can have a Sapphire person contact you with more info including a "test drive" . Also with our financing program things can be more affordable than you might think.
As for new cargo van designs we have been working on these since the transit connect was introduced. Innovation never stops!!!
Dan
Dan
Bill, it would be nice to see full specs on the website. Some of us techy guys like details.
Yea I would think it's going to need to be more than just a CFM number, you'll need to factor in inches of lift too. How much mercury can it pull also!
clean image
Carl Maddock
It rated over 700 at 10hg
My question on what makes these blowers 4-10 have such higher lift than standard 4007 trilobe
Leeeme take this opportunity to recant my statement about enjoying that you post here. :cry:
You suck! :p
LOL
Tell me where you said that.
I want to go read it before Mikey or Fred edits it out.
