White cotton and grey linen
After browsing for hours in past posts, I just need advice. This chair is cotton, scruffy from a recent move. Inside, the cushions are synthetic batting covering a down pillow.
The lady attempted to clean coffee from the pictured corner with Resolve.
She generated the wide, faintly yellow stain pictured.
My thought: 1. Flush with distilled water and suck it as dry as possible, maybe use hair dryer to speed it up.
2. Use an encap product (Releasit DS2) and a hand pad to lightly clean the surface, let it dry and then vacuum.
(Or)
2. Use something Interlink (local chempimp) and follow directions.
3. Repeat on a linen couch.
(Or)
4. Be willing to be coached if anyone has better ideas.
View attachment 77131 View attachment 77132 After browsing for hours in past posts, I just need advice. This chair is cotton, scruffy from a recent move. Inside, the cushions are synthetic batting covering a down pillow.
(Or)
(Or)
Tarps or move it keep wood dry!
I would Pre spray with either Cobb’s uph pre spray with a dash of brightner!
Rinse with last step and a scoop or two of natural fiber cleaner cti!
And lightly pre spray and hand bonnet, then real low flow rinse lots of dry strokes and fans.
If you have a dry type of upholstery tool, HWE should be fine process. You can also shampoo and rinse with extractor.
Avenge Fabric Shampoo. Boost with a moderate amount of Boost All. Rinse with Fab-Set.
or
Shampoo with Oxy Buff Shampoo. Generate the foam and use a horse hair brush to work this into the fabric. Give a little dwell time. Rinse with Fab-Set.
Encapsulation is another alternative. May not help much on the yellow staining from the Resolve. I suggest an Encap product with O2 such as Encapuclean O2. Rick's O2 product will fine if you already have that.
Scott, I thought of Hydrox but worried the peroxide would damage the cotton. I use Avenge regularly, but not a rinsing agent. The reason is that I don’t have an inline injector.
However, I do have Fab-Set. Would rinsing (SS tool) then spraying with Fab-Set and dry sucking it again work? See, I have real concerns about over wetting the cotton
Yes, it will work, and yes dry it quickly. You might try some fresh 3% hydrogen peroxide on the stains; nothing stronger,
Make no guarantees on this. What she did will make your job harder.
I am going to be in Death Valley tomorrow with no internet access and limited cell coverage. You can call or text me at 412-414-9129 if you want to discuss this more. As soon as a message comes through I will call
Peroxide at 3% should not harm the cotton unless there was some pre-existing issue such as age and exposure to a lot of UV light. It is always good to test first, but you should be alright.
If you have a dry type upholstery tool, I would just rinse well with Fab-Set or plain water and forget post=spray with Fab-Set. This will help avoid over-wetting.
Thank you Scott. They came out wonderfully and the lady seemed very pleased. Sure did take a while.
Reactions: J Scott W
I flushed the stains with distilled water, then sprayed with Avenge. A scrub with a soft brush broke up most spots, then I flushed with warm water. On coffee spots I used 3% peroxide in a little spray bottle (comes from Walgreens), let dwell and rinsed.
Lots of dry passes to suck water, pulled the surface away from visible feathers because they bleed dark. A blower to speed drying on each piece.
