white magic 56...
Mike Draper
what RPM does white magic spin their 56 blower at? Curious. Also, what is the HP rating on the drive line clutch they are using to spin the blower?
Mike Draper
1,500 rpm on the blower would be 222 CFM @ 10hg. I just dont see how they have any performance at that rpm? Are you sure that is not the engine RPM?
Ray Burnfield
Ray Burnfield
That is the engine RPM. The manuals don't provide the rpms for the blower.
Ray Burnfield
Ray Burnfield
Came across some notes in one of the manuals that had 1850-1900 rpms for the blower.
I don't know if that is accurate or who wrote the notes.
Hope it helps.
If you know the pulley size you can figure the blower speed. Look in the manual.
Gene
AshleyMckendree
Ashley Mckendree
One I had blower was spinning at 2000 RPM, I changed the ratio to spin it 2300, and set the relief at 17, Crazy power.
Had the friggin military spec 7" serpentine clutch, I also ran a Gates Green HD serpintine belt, never slipped after that.
Reactions: glenboy
