Ok Rich,
Watch the OLD MANS (blood pressure) hit the roof :shock: :shock: :shock:
Soap is not the ONLY enemy of your blower :!: :!:
Actually there should be NO SOAP built-up in your blower :shock: :shock:
Soap residue can only get in the blower if the Waste Tank is full & shuts down unit :!:
Or your are cleaning a job that is FULL OF SOAP...Then you need a DEFOAMER.......
BaWB...Has NEVER seen the inside of his waste tank
..They should be cleaned
EVERY DAY..IMO...
If you DON'T do proper maintaince on your W-Tank....Moisture from the tank migrates
into your blower & causes SURFACE RUST....That is why blower can SEIZE if they have
sat for long periods of time
OIL & WATER don't mix....Soooo as we spray WD 40 in our blowers day after day It ...
BUILTS -UP .....collecting all the dust & pollutants ect...."ever dry-vac with your unit"
WELL .......If the tank is empty all the lint & dust goes through the blower!
"Blowers don't have HEPA filters."
My point is ..You need a DETERGENT to Cut through the GUNK that builds-up & COOKS inside the BLOWER :!: :!: :!:
BaWb the "GOOBER"... is correct about FLUSHING the with clean WATER :!: ......
AFTER IT IS CLEAN
